I would put fans in front of the graphics card and storage drive. The CPU cooler drags air better than those on graphics cards, while storage drives are cooled passively. The latter two need more help from case fans.
Desktop benching:
https://linustechtips.com/topic/967256-fan-placement/#findComment-11708603
Ah perfect, will just mount them together as option 1 then
https://linustechtips.com/topic/967256-fan-placement/#findComment-11708633
