Very Low FPS
Go to solution Solved by Void Master,
you did a mistake all people do
just plug it to the gpu and enjoy 60 fps at the ultra settings !  :-)
Hello guys, since 5 days i have very poor performance while gaming. CS GO is running at 15fps and with all low settings at max 19. I tried reinstalling drivers and reinsatlling the game.Also i deaktivatet Game DVR and it didnt effect the performance. Does anybody know a solution there?? (i5 7500, GTX 1060 6GB)
Thank you!
https://linustechtips.com/topic/967223-very-low-fps/
Thank you!
System specs would help a lot bro.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708319
Just now, Sadleast said:
i edited it
Can you check if your game is running on your GPU or the integrated one?
Sometimes this happen.
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708326
i edited it
What did you do 5 days ago?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708327
i checked that. It is indeed running on the gtx 1060. Had the same idea and reinstalled Geforce drivers and checked that it was handling the games.
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708332
did you plug you monitor's cable to the gpu or the motherboard ?
Please quote or tag me @Void Master,so i can see your reply.
Everyone was a noob at the beginning, don't be discouraged by toxic trolls even if u lose 15 times in a row. Keep training and pushing yourself further and further, so u can show those sorry lots how it's done !
Be a supportive player, and make sure to reflect a good image of the game community you are a part of.
Don't kick a player unless they willingly want to ruin your experience.
We are the gamer community, we should take care of each other !
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708333
look , try resetting or reinstalling windows
I believe its an issue in windows
Edited by Void Master
this is wrong
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708338
plug it to the gpu
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708345
I believe you will see a BIG difference
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708348
3 minutes ago, Sadleast said:
Does it make a difference if its not plugged in the GPU? i currently have it plugged in Motherboard
wtf? was it always plugged in the motherboard? how the hell were you gaming that way?
monitor should be plugged directly to the GPU....
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708352
I was moving and didnt put together all of my stuff. A friend of mine put it together again.
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708354
do not reset it
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708355
you don't need to reinstall windows or drivers.. just plug the monitor to the GPU and that's it, your problem is solved.
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708358
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708359
did it work ?
https://linustechtips.com/topic/967223-very-low-fps/#findComment-11708366
