What software did u use to clone it?
I cloned mine using Samsung Migration Software and it works like wonder.
If you're using other softwares, make sure u copied the recovery and also the UEFI partition.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/966969-samsung-970-evo-help/#findComment-11706112
I used Macrium Reflect
https://linustechtips.com/topic/966969-samsung-970-evo-help/#findComment-11706115
Did i copy the uefi and recovery partition as well?
What id recommend u to do is just boot from the older storage, install samsung migration tool,  clone the drive, remove the older storage and boot.
https://linustechtips.com/topic/966969-samsung-970-evo-help/#findComment-11706201
Yeah thats what i have started to do, im not gonna clone it yet tho I'll do it over night. Thanks for your help. Hopefully it works. :)
https://linustechtips.com/topic/966969-samsung-970-evo-help/#findComment-11706244
Ok so i thought it was gonna take longer but i have done it now, clone it i mean. I have also gone into the Bios and changed the boot priority to the SSD and entered the boot menu and selected the SSD as well but i get the same message.  " no operating system was found try disconnecting all other drives that dont contain the OS. Would formating the HDD that originally had the OS on help at all?
https://linustechtips.com/topic/966969-samsung-970-evo-help/#findComment-11706359
