4 minutes ago, yasir_786 said:
Yeah gotcha mate. Really appreciate your help. After much thinking & researching i guess I'll go for Ryzen 3 1300x + Asus Prime B350m-k + Zotac GTX 1050ti mini 4gb. An year later I'll upgrade to a Ryzen 5.
I guess this motherboard is good right?
That one definitely doesn't have any VRM heatsinks. Do you need a micro ATX board ? What case do you have ?
2 hours ago, yasir_786 said:
Yeah man thanks. Also
after much thinking & researching i guess I'll go for Ryzen 3 1300x + Asus Prime B350m-k + Zotac GTX 1050ti mini 4gb. An year later I'll upgrade to a Ryzen 5. Sounds reasonable enough i guess
hey thats a good idea. I'm going for a 1200 personally and I don't really see that much of a difference in games on average between ryzen 3, 5 and 7. Better CPU allows for better GPUs but games are GPU (textures, rendering etc)/SSD (for load times) bound.
There are 10 types of people in this world. Those that understand binary and those that don't.
Current Rig (Dominator II): 8GB Corsair Vengeance LPX DDR4 3133 C15, AMD Ryzen 3 1200 at 4GHz, Coolermaster MasterLiquid Lite 120, ASRock B450M Pro4, AMD R9 280X, 120GB TCSunBow SSD, 3TB Seagate ST3000DM001-9YN166 HSD, Corsair CX750M Grey Label, Windows 10 Pro, 2x CoolerMaster MasterFan Pro 120, Thermaltake Versa H18 Tempered Glass.
Previous Rig (Black Magic): 8GB DDR3 1600, AMD FX6300 OC'd to 4.5GHz, Zalman CNPS5X Performa, Asus M5A78L-M PLUS /USB3, GTX 950 SC (former, it blew my PCIe lane so now on mobo graphics which is Radeon HD 3000 Series), 1TB Samsung Spinpoint F3 7200RPM HDD, 3TB Seagate ST3000DM001-9YN166 HDD (secondary), Corsair CX750M, Windows 8.1 Pro, 2x 120mm Red LED fans, Deepcool SMARTER case
My secondary rig (The Oldie): 4GB DDR2 800, Intel Core 2 Duo E8400 @ 3GHz, Stock Dell Cooler, Foxconn 0RY007, AMD Radeon HD 5450, 250GB Samsung Spinpoint 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management. UPDATE: SPECS UPGRADED DUE TO CASEMOD, 8GB DDR2 800, AMD Phenom X4 9650, Zalman CNPS5X Performa, Biostar GF8200C M2+, AMD Radeon HD 7450 GDDR5 edition, Samsung Spinpoint 250GB 7200RPM HDD, Antec HCG 400M 400W Semi Modular PSU, Windows 8.1 Pro, 80mm Cooler Master fan, Dell Inspiron 530 Case modded for better cable management and support for non Dell boards.
Retired/Dead Rigs: The OG (retired) (First ever PC I used at 3 years old back in 2005) Current Specs: 2GB DDR2, Pentium M 770 @ 2.13GHz, 60GB IDE laptop HDD, ZorinOS 12 Ultimate x86. Originally 512mb DDR2, Pentium M 740 @ 1.73GHzm 60GB IDE laptop HDD and single boot XP Pro. The Craptop (dead), 2gb DDR3, Celeron n2840 @ 2.1GHz, 50GB eMMC chip, Windows 10 Pro. Nightrider (dead and cannibalized for Dominator II): Ryzen 3 1200, Gigabyte A320M HD2, 8GB DDR4, XFX Ghost Core Radeon HD 7770, 1TB Samsung Spinpoint F3 (2010), 3TB Seagate Barracuda, Corsair CX750M Green, Deepcool SMARTER, Windows 10 Home.
That motherboard is my max budget for a motherboard. I've an ATX Case, it's from an Indian brand : Circle Cc830
And i want a b350 mobo because i might overclock the 1300x. & the good motherboards like asrock b350m pro or MSI b350m pro vdh aren't available on any site here.
I'm buying from this site, it has the best rates.
https://www.primeabgb.com/
And if you might check out the site, thanks for that, my budget is like 6.8k Rs. The mobo i mentioned is of that price too. Here in India it's hard to get pc components for fair price & most of the times the good ones are out of stock.
Update : I might try real hard & get the MSI B350M Bazooka Motherboard, i read its reviews & it's VRM are nice & overall it's a good cheap motherboard, although it ain't cheap for me lol.
Yeah right, & building a ryzen 3 build will give you an upgrade path too. Plus you seem to be much gaming oriented than editing so the cpu will just be fine, if you get a 1050ti or a better gpu then you are good to go. I just have basic knowledge of pc stuff but I'm learning hahaha. Hope you build your pc soon :)
I'm getting there slowly. Hopefully I can get it done by Christmas or something.
I don't know about the MSI Bazooka. The MSI Tomahawk is supposedly pretty decent. In any case you should maybe try and save up a bit more money and buy a decent board from the start, otherwise you will find yourself having problems down the road, especially if you ever go with a 6 or 8 core Ryzen cpu.
Have a watch of this video from Buildzoid who goes over the B450 chipset in good detail and talks about VRM's etc.
Oh, yeah the Tomahawks is really decent but unfortunately here in India it's either very expensive or not available most times. And as for the Bazooka, it's a good motherboard, has nice features & i read some nice reviews on the motherboard, overall seems positive.
And huge thanks for all your help & heads up for this motherboard knowledge, will surely watch the video,much needed hahaha.
On 8/31/2018 at 4:28 PM, yasir_786 said:
I'm building my first pc, sold my crappy pc & ps3 about 2 years ago & bought a Psu, Ram stick, Cabinet, HDD, Keyboard & Mouse.
Now in a week or so I'll be buying the rest of the parts i.e CPU, GPU & Mobo.
I want some help regarding the system I'm building, whether it'll be future proof, okay for gaming, good for photo /video editing & I'm curious whether the motherboard choice is good or not, it's a cheap motherboard but the good ones in budget aren't available & alternative mobo are expensive.
My budget for cpu, mobo & gpu is total around 26,000 Rs. (366$)
System config :
Amd Ryzen 5 1600
ASUS EX-A320M-GAMING Motherboard
Wd Blue 1tb 7200 rpm
Corsair Vengeance LPX 8gd DDR4 2400 mhz Ram.
Zotac Gt 1030 2gb GDDR5
Corsair VS450 PSU
I pretty much don't plan to OC, but still I'm not sure whether the mobo is good or not, there is a cheaper choice Asus Prime A320m - k & a somewhat expensive Asus Prime B350m-A which will make my budget slightly increase.
Really appreciate who helps.
Thank you.
Build something like this...
I know that I have opted fr x370 board coz it's going on fr pretty cheap on Amazon India....it's currently in the a320 territory price wise....u can Chuck in an SSD if needed.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  (₹6284.00 @ Amazon India)
Motherboard: Gigabyte - GA-AX370-Gaming ATX AM4 Motherboard  (₹5873.39 @ Amazon India)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory  (₹5873.39 @ Amazon India)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (₹3125.00 @ Amazon India)
Video Card: EVGA - GeForce GTX 1050 Ti 4GB ACX 2.0 Video Card  (₹12481.78 @ Amazon India)
Case: Corsair - Carbide SPEC-04 (Black/Red) ATX Mid Tower Case  (₹3250.00 @ Amazon India)
Power Supply: Cooler Master - MasterWatt 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  (₹3413.60 @ Amazon India)
Total: ₹40301.16
Generated by PCPartPicker 2018-09-02 12:58 IST+0530
Total: ₹40301.16
Hey man, i really appreciate your help. But Amazon India has one of the worst prices for computer components. & that gigabyte X370 mobo is worth almost 10k on Amazon.
I've researched every good site of sellers & have found the Ryzen 3 + MSI B450M Bazooka Plus Motherboard + Zotac Gtx 1050ti Mini 4gb GDDR5. This exceeds my budget by a little margin but this is the best cheap setup. As for the ram & rest of the parts i bought them already 2 years ago.
On 31/08/2018 at 4:34 PM, Supportsneedlove said:
I don't know if that GT 1030 is going to hold up in video editing. I'd get a better GPU, go used if you have to. Don't know too much about motherboards, the CPU seems a little overkill for the GPU and the ram might limit the CPU a bit.
Other than that it looks alright (although I would personally get an SSD)
I'd personally recommend the GTX 1050 or 1050ti both are  amazing I'm using it rn and with medium to high settings on Fortnite I'm getting around 60-100 frames
Yeah I'm including that in my Ryzen 3 build. Thanks for the heads up
What's ur budget btw??
