So I'm really ready to pull the trigger on a 1950x what do you think about my setup, I would like to use as much of my current hardware as possible my concern is I have a 750 watt thermaltake PSU and would be powering a GTX 1080 and an AIO along with the CPU other than an nvme ssd for the os and maybe 1 HDD as I have a network NAS am I pushing the limit? I would prolly like to run a mild oc just concerned I'm on the edge of overload?
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/966703-tr4-system-power-draw/
1950x draws about 300w when overclocked to about 4GHz, 1080 reference starts at 180w but some custom cards can draw 250w when overclocked. Adding in another 150w for other stuff, your PSU has the wattage to handle everything.
however, wattage doesnt make a PSU good (Thermaltake isnt the best of power supply brands either). What model are we talking about?
Desktop benching:
https://linustechtips.com/topic/966703-tr4-system-power-draw/#findComment-11703561
It's the toughpower model think it made the tier 2 list on here I don't game so won't be oc'ing the GPU if you look at my signature I will be swapping out the technology rig with the mobo, cpu and ram which brings up another concern currently it is 3200MHz and I see TR4 is 2667 is that anything to worry about?
https://linustechtips.com/topic/966703-tr4-system-power-draw/#findComment-11703626
ram isnt a problem, you can overclock that just like you have now,
Desktop benching:
https://linustechtips.com/topic/966703-tr4-system-power-draw/#findComment-11703824
