Howdy,
I am wanting to build a NAS and have a couple of questions and definitely am in need of some assistance.
Backstory:  I use a laptop at home(dockingstation) and use PLEX to serve video files to TVs and remotely.  I have an external 4-bay HDD enclosure.  With a 4TB, and 3 1TB HDDs(JBOD).  One day I try to play a video file and PLEX reports that the video file is not there.  Long story short, something happened with the external enclosure and I lost about 80% of my data across all the drives.  I no longer use this external enclosure.
Currently:  I have the before mentioned laptop and an old HTPC/Gaming rig from a few years back.  Haven't really used the gaming rig in a while.  A8-5600k w/280X.  I would like to turn the old HTPC into a NAS with fault tolerance.  I know LTT did a unRAID w/Windows virtualized.  And this looks very appealing.  The only thing unappealing about that is having to buy 2 new HDD and the single disk read/write speeds for the disks.  Also my motherboard is limited to 4 SATA III ports.  So that could be an issue in the future when upgrading storage.  I would also need to virtualize a Windows based system for my Wife/Daughter to use, which I know is not an issue with unRAID.
1.  Is there a native NAS app for Windows?  This would be the perferable route for me since my family and I are familiar with Windows.
2.  Is there another NAS product that can run headless and also do a VM for Windows?
3.  I have read that ZFS is a superior NAS protocol, but I am not 100% sure on that.  Is this the case?  I know it would allow me to use different sized HDDs.
4.  Would just a commercial NAS fit my bill?  It would also need to be able to use Radarr/Sonarr and some form of NZB downloader.  As well as PLEX.  I feel like I can build a much more robust PC rather than get a commercial NAS.
Any help would be appreciated.  I am not set on any one thing so this is just a work in progress.
https://linustechtips.com/topic/966632-building-nas-need-help/
This is the route I have taken repeatedly. It's a lot less headache, and using X-RAID (eXpandable RAID) increasing the size of the RAID is a snap, take out 1 drive, put in a larger drive, let it re-sync, done. Wash rinse repeat.
No maintenance, no fiddling with, just set it and forget it (backups as an exception of course) no headaches.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/966632-building-nas-need-help/#findComment-11702893
You can easily share files in windows, just right click on a folder and share.
Most can, but really don't bother with vms here.
Its better in some ways, but really you won't notice the difference here.
It will work fine.
But really, id just share a folder on the old pc. No reason to change os here. Then add some hdds and use storage spaces to store all your data.
https://linustechtips.com/topic/966632-building-nas-need-help/#findComment-11703331
