Hi so recently I did a reshuffle of my pcs formatted all drives and the reinstalled windows but the problem I seem to be having is windows installs fine I boot up get onto windows but when the drivers install it leaves the screen black however the monitor is still receiving a signal how would I fix this? Happening on two of my computer now
https://linustechtips.com/topic/965846-help-is-required/
Are you sure you have the right drivers? It seems like the drivers that are being installed are wrong. Disable Windows from automatically installing drivers, and try installing them manually.
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/965846-help-is-required/#findComment-11695501
41 minutes ago, Kingj941 said:
Doesn't work half Wal through install I get this
Its normal for it to go black during the installation. It shouldn't do this permanently though. You waited with the screen black for a bit of time or did you simply turn it off?
https://linustechtips.com/topic/965846-help-is-required/#findComment-11695893
