cpu cooler
Go to solution Solved by Hrodberht,
13 minutes ago, Play_Ah_Me said:
no it only has one.
It looks like you are supposed to use your stock mounting bracket to clip the Hyper t4 onto.
I recently bought a cooler master hyper t4 and when it arrived, the part that goes in the back of the motherboard was the wrong size. It was more of a square size . I have the asus rog strix b350-f gaming and the back plate for that one was taller. What should I keep an eye out for in the specifications for when looking for a cpu cooler and when they don't include images of the size of the back plate?
https://linustechtips.com/topic/965511-cpu-cooler/
Well what do the mounting instructions say for AM4?
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692293
Quick Google: your motherboard has an AM4 CPU socket.
The Cooler Master Hyper T4 does not support AM4.
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-t4/
-> " Versatile all-in-one mounting solution supporting the Intel  LGA 2011/1366/1156/1155/1150/775 and AMD FM2+/FM2/FM1/AM3+/AM3 /AM2 "
i5-8600k delidded + Conductonaut - msi Z370-A Pro - Corsair Vengeance LPX 3000 2x8GB - be quiet Dark Rock 3 - Zotac GTX 1070 mini
Meh.
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692325
I see that now. On the name it said with am4 support but in the description it doesn't have it as support for am4. Well that's dumb of me to oversee.
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692339
@Play_Ah_Me If your looking for an AM4 cooler then i would recommend the Arctic Cooling range of fans.
Ive used quite a few on AM3/4 and them seem to be reasonably priced and perform well.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692360
Actually, I'm not sure anymore right now. Took another look at the page I linked and while it doesn't list either LGA 2066 or AM4 in the description, they are listed in the specs. And on their website they advertise it "with AMD Ryzen AM4 bracket compatibility right out of the package".
Is there any other mount in the cooler's package perhaps?
Meh.
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692374
If it lacks Am4 support then it will not have a bracket to support.
This is a good cooler on Amazon and reasonably priced.....
https://www.amazon.co.uk/Arctic-Freezer-33-passive-performance/dp/B06WV898Y1/ref=sr_1_5?ie=UTF8&qid=1535414883&sr=8-5&keywords=Arctic+Cooling+Am4+fan
Internet Speed.....
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692380
no it only has one.
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692382
no it only has one.
Meh.
https://linustechtips.com/topic/965511-cpu-cooler/#findComment-11692410
