Difference between var and let
Solved by 0x21,
Variables declared by let have their scope in the block for which they're defined, and any contained blocks. The scope of var is that of the entire enclosing function. Also, unlike var which will initialise with the value undefined, let variables are not initialised until evaluated.
function varExample() { var n = 1; if (n === 1) { var n = 2; console.log(n); // 2 } console.log(n); // 2 } function letExample() { let n = 1; if (n === 1) { let n = 2; console.log(n); // 2 } console.log(n); // 1 }
