Random restarts, kernel-power
Solved by BrandedBow,
If it is stable under load, then maybe there was an issue with just the drivers.
If that is the case, just re-install the drivers and use your computer normally and see if the same issue is still present.
I found the issue. It was a connection issue with the power to the graphics card, so whenever i shake the table or the computer a little it would cut off power to the card. Sorry for the inconvienience and thanks for helping anyway!
