13 minutes ago, Nabbie said:
Can you look  at my pc and say if its good or no i planing use 1080ti or 2080ti https://pcpartpicker.com/list/dKmNYT + do i need choose wifi adapter , sound card and i need some rgb effects i love them so please help me in my country nobody helped me in forums :(
https://pcpartpicker.com/list/ZgV26s
i changed the RAM and the Power Supply (850w is overkill for 8700k and 1080ti) :) everything else is great.
and that motherboard comes with Wifi, and it's up to you if you wanna upgrade the soundcard, try the onboard soundcard first.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/964859-pc-building-help/#findComment-11686539
it's fine, but you don't need a 3600mhz kit or an 850w psu.
https://linustechtips.com/topic/964859-pc-building-help/#findComment-11686578
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($359.99 @ Amazon)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler  ($149.99 @ Newegg)
Motherboard: Gigabyte - Z370 AORUS Gaming 7 (rev. 1.0) ATX LGA1151 Motherboard  ($227.19 @ OutletPC)
Memory: Team - Night Hawk RGB 16GB (2 x 8GB) DDR4-3200 Memory  ($164.99 @ Newegg)
Storage: ADATA - XPG  512GB M.2-2280 Solid State Drive  ($104.89 @ OutletPC)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  ($56.49 @ OutletPC)
Case: Corsair - Carbide Series 275R (White w/Tempered Glass) ATX Mid Tower Case  ($79.99 @ Amazon)
Power Supply: EVGA - 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($55.98 @ Newegg)
Other: CableMod Basic Cable Extension Kit - 8+6 Pin Series - White  ($34.95 @ Amazon)
Total: $1234.46
Generated by PCPartPicker 2018-08-26 08:20 EDT-0400
https://linustechtips.com/topic/964859-pc-building-help/#findComment-11686594
Look at this https://pcpartpicker.com/list/mbtkHh some parts in my country shop i cant find especially i want buy from one shop cuz i gonna ask shop to made it i'm not gonna build it myself so if you gonna edit some parts please search in shop called Skytech (ofc its in my language but most thing you need to know is in English btw i live in Lithuania if that helps). These parts link in shophttp://www.skytech.lt/co9050029ww-corsair-case-fan-air-series-sp120-red-led-120mm-3pin-twin-pack-p-215456.html (I don't know how much i need them can you say how much?)
PSUhttp://www.skytech.lt/220g20750x2-psu-evga-supernova-750-750w-plus-gold-full-modular-p-343133.html this shoud be good right?
Casehttp://www.skytech.lt/3021-azza-inferno-310-with-rgb-fans-tempered-glass-side-window-usb-spk-mic-black-p-369940.html idk i like this case but i don't know if anything fits in it, so do it fits?
SSDhttp://www.skytech.lt/mzv7e500bw-samsung-ssd-970-evo-nvme-pcie-500gb-34002300mbs-p-390163.html well i don't like Adata products idk do i overdoing to choosing this?
RAMhttp://www.skytech.lt/cmw16gx4m2c3200c16w-corsair-vengeance-rgb-series-led-16gb-3200mhz-ddr4-cl16-p-395440.html I can't find ram like Team-Night Hawk on this shop so i choosed this is it good let me know.
Motherboardhttp://www.skytech.lt/z370-aorus-gaming-7op-gigabyte-z370-aorus-gaming-7op-p-393216.html is it this one if no please come check in store?
Thank you for your helps very appreciate(damn I'm so bad at English :P)  Please feel free change any parts and I'm waiting for benchmark for RTX2080ti I don't know if it gonna be worth to buy cuz in our country 1080ti cost around 900Eu and i heard RTX2080ti gonna cost around 1.3k eu so I don't wanna throw money away I guess I'm right? if no correct me.
https://linustechtips.com/topic/964859-pc-building-help/#findComment-11686745
