2 minutes ago, siroofsalot said:
My alienware is getting 99c under stress test, dell tech said it is fine
Well, that just about sums up Alienware in a single sentence.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/964727-overheating/#findComment-11685399
On a serious note, your build plan is great. The thing I would change is getting Arctic MX-4 and not the Arctic Silver 5, I've used both and the MX-4 is far superior.
It would be a great choice to sell your Alienware and buy a new system.
https://linustechtips.com/topic/964727-overheating/#findComment-11685402
ok i will possibly depending on how much on ebay i could get, new is 1900 but i am looking to sell 1700-1600
https://linustechtips.com/topic/964727-overheating/#findComment-11685408
What are your specs? Why replace the psu?
https://linustechtips.com/topic/964727-overheating/#findComment-11685622
8 hours ago, siroofsalot said:
it is stock air cooling 460 watt psu nvidia 1080 intel i78700
Stock intel cooler or stock cooler that came with the prebuilt? Have you tried cleaning the cooler of dust?
What's the system model name?
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them.
https://linustechtips.com/topic/964727-overheating/#findComment-11688796
And there's your problem. 8700 has some voltage issues, so it probably uses way too high voltage when you stress it. There's easy fix by setting manual voltage. This can be done on locked chip as its only multiplier which is locked. You could even do some OCing with locked chip by manipulating base clock.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/964727-overheating/#findComment-11689419
