Tx Power adjustment?
By
AllaboutPC
in Networking
in Networking
Solved by LAwLz,
Tx = sending a signal.
Increasing it will increase the strength of the signals you send. If you don't get the speeds you want/expect then you can try increasing the output wattage.
3
thedood2k ·
Posted in Power Supplies2 -
DARTHDIVIDER0213 ·
Posted in Troubleshooting8 -
1
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
