6 hours ago, Jbnlgamer said:
I want to juse a addresable ledstrip on my asus rog strike z370-f but i dont know how long i can go can someone tel me that in meters and not in foot i am europe guy i dont know about inches
Btw the led strip i want to juse is the akasa vegas mba
Tnx
Welcome to the Forums!
As always refer to the manual, for addressable LED's you will want to look at the actual number of LED's and the density per meter of LED strip.
Quote
*The addressable RGB header supports WS2812B addressable RGB LED strips (5V/Data/Ground), with a max power rating of 3A (5V) and a max of 60 LEDs.
* The Aura RGB-strip header supports 5050 RGB LED strips with a max power rating of 3A (12V). For maximum brightness, strip length should not exceed 3m.
**RGB and addressable RGB extension cables are included. LED strips and Aura Sync-compatible devices are sold separately.
https://linustechtips.com/topic/964675-addresable-led-strip/#findComment-11685757
4 hours ago, Jbnlgamer said:
that good i need 2.5 meters
so i go to order it
tnx for the help
Take note 3M limit is not for the addressable RGB LED’s, you must take account of the density and number of LED chips for the addressable option. You cannot exceed more than 60 LED’s as said.
https://linustechtips.com/topic/964675-addresable-led-strip/#findComment-11687153
