Hello! I'm interested in building a PC by the end of the year to play games like PUBG, Rainbow Six, Arma 3, Overwatch, and other similar games. I want to play them at 1080p 144hz. I currently have the 1070 Ti on the list but if the 2060 comes out for a similar price I'll buy that instead. Also, I'd like to stay below $1500 dollars and I like the black and white aesthetic.
https://pcpartpicker.com/list/Mfcqr6
In the future, I plan on buying the:
Logitech G513 (Keyboard)
Logitech G403 (Mouse)
Sennheiser 598SR (Headphones)
Modmic 5 (Microphone)
and for cooling and lighting,
Corsair LL120 RGB 120mm Fans x1 (For rear exhaust)
Corsair LL140 RGB 140mm Fans x4 (Top Exhaust and front intake)
Corsair Commander Pro (Fan and LED Light Strip Hub)
Corsair RGB LED Lighting PRO (Light Strips)
Am I missing anything I need to run the PC or to run the fans through Corsair's software? If anyone has any questions I'd be glad to answer them, thanks for all of your help.
https://linustechtips.com/topic/964324-first-pc/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor  ($165.99 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($109.99 @ Amazon)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($154.99 @ Amazon)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive  ($98.89 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.09 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB D5X Video Card  ($429.99 @ Newegg)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($88.88 @ Newegg)
Power Supply: SeaSonic - FOCUS Plus Gold 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor  ($199.83 @ Amazon)
Total: $1377.64
Generated by PCPartPicker 2018-08-24 18:26 EDT-0400
Build optimizations and room for stuff you want to add
https://linustechtips.com/topic/964324-first-pc/#findComment-11682374
1 minute ago, Matty2048 said:
you need to make sure you have enough 4-pin connectors on the mobo for all the fans + lights so they can be controlled if not buy a controller/spliter
Does the Commander Pro not do that? I thought I would plug in the RGB and the Fan cables into that and not the mobo
https://linustechtips.com/topic/964324-first-pc/#findComment-11682375
Total: $1377.64
Ok so a few questions
Can you turn off those horrendous red LEDs on the Motherboard?
And why did you change the PSU?
Thanks for the help
https://linustechtips.com/topic/964324-first-pc/#findComment-11682385
Solid build all around, though I would probably purchase a secondary HDD as 500GB does not last long when loading it up with games alongside your OS.
As the current owner (and soon to be former owner) of the Modmic 5, I don't really recommend it. The sticky pads don't last long especially if you tend to get sweaty or are prone to having oily hair. The mic quality is unremarkable and as a whole the kit is overpriced for what you get.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682390
What are you replacing it with?
https://linustechtips.com/topic/964324-first-pc/#findComment-11682392
An Audio-Technica AT2020 mic.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682394
Total: $1377.64
Isn't a 1080 a little much power for 1080p 144 Hz?
https://linustechtips.com/topic/964324-first-pc/#findComment-11682399
1 minute ago, OGH2020 said:
USB version or the second version?
Second version?
I don't want a USB mic. Mine will be using XLR cables going to a mic amp I'll be getting in a month off a friend IRL.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682407
Thanks for the help
I believe you can in the BIOS or in some MSI software. Or you can opt for the B450 PRO4 from ASrock that doesnt have LEDs
This PSU is cheaper and is of good quality and will last you a good while
https://linustechtips.com/topic/964324-first-pc/#findComment-11682413
Lol sorry I didn't know what the non-usb version was called
Not a problem.
The USB version is decent if you have the USB output from the mic going to an audio interface to boost the signal, otherwise it'll be very quiet.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682418
Id rather not, I think I'd rather save some more money and do a cheaper 1070 Ti or 1070
I recommend the 1070TI as the price difference is minor compared to a 1070 but approaches within ~90% of the performance of the 1080.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682423
But will the 1070 be able to do Medium-High settings at 144hz? I want to save some money so I can build it sooner. Thanks!
https://linustechtips.com/topic/964324-first-pc/#findComment-11682430
Yes it can.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682434
1080 is at 1070ti pricing. And the 1070 isnt far for the 1070ti. Might aswell grab the 1080.
2 minutes ago, OGH2020 said:
Is it possible for you to make this build cheaper? I don't know which GPU would be a better value for medium-high settings at 144hz
You cam probably do an RX 580 with a freesync panel at those setting in many games
https://linustechtips.com/topic/964324-first-pc/#findComment-11682435
6 minutes ago, OGH2020 said:
Is it possible for you to make this build cheaper? I don't know which GPU would be a better value for medium-high settings at 144hz.
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard  ($82.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($144.99 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Video Card: XFX - Radeon RX 580 8GB GTS XXX ED Video Card  ($239.99 @ Amazon)
Total: $1116.73
Generated by PCPartPicker 2018-08-24 18:50 EDT-0400
Significantly cheaper and better value
A freesync display to remove tearing and reduce the effect of drops in FPS
https://linustechtips.com/topic/964324-first-pc/#findComment-11682443
Thank you so much for all your help. I'll adjust my build so it has an RX580, a cheaper SSD and maybe a second HDD. Would it be stupid to do a 120gb M.2 SSD for the OS, and a 500gb Sata SSD for my games, and no HDD? I don't do that much other than game on the PC and use cloud based websited for my documents for school and such.
https://linustechtips.com/topic/964324-first-pc/#findComment-11682445
I allready did all the neccesary changes in a post above. A 2TB HDD is the bwst choice. Games dont benefit from slightly faster load times and the capacity will last you a very long time
https://linustechtips.com/topic/964324-first-pc/#findComment-11682455
