There is one customer kernel for that phone. It will be faster due to tweaks but no overclocking.
https://forum.xda-developers.com/p8lite/p8-lite-2017-development/kernel-labyrinth-kernel-huawei-p8-lite-t3809701
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/964258-help-with-custom-kernel/#findComment-11698631
5 hours ago, Airpewdiepie said:
if it would work flawlessly without any brick then around 15
 (i have changed rom to dot os 8.1)
i dont mind bricking if i can recover.
just something to mull over, a professional freelance developer cost is anywhere from $50 to $100+ an hour. You're not likely going to find someone who wants to do all the work for this for $15. You could probably find a CS student to do it for around $10/hr, but the chances of them being able to finish this task in only a few hours is probably slim unless you happen to find the next bill gates who's just about ready to drop out and make microsoft 2.
EDIT: I may have this wrong though. Are you looking for someone to develop a brand new kernel, or are you looking for someone to find an existing kernel and help you load it?
Gaming build:
CPU: i7-7700k (5.0ghz, 1.312v)
GPU(s): Asus Strix 1080ti OC (~2063mhz)
Memory: 32GB (4x8) DDR4 G.Skill TridentZ RGB 3000mhz
Motherboard: Asus Prime z270-AR
PSU: Seasonic Prime Titanium 850W
Cooler: Custom water loop (420mm rad + 360mm rad)
Case: Be quiet! Dark base pro 900 (silver)
Primary storage: Samsung 960 evo m.2 SSD (500gb)
Secondary storage: Samsung 850 evo SSD (250gb)
Server build:
OS: Ubuntu server 16.04 LTS (though will probably upgrade to 17.04 for better ryzen support)
CPU: Ryzen R7 1700x
Memory: Ballistix Sport LT 16GB
Motherboard: Asrock B350 m4 pro
PSU: Corsair CX550M
Cooler: Cooler master hyper 212 evo
Storage: 2TB WD Red x1, 128gb OCZ SSD for OS
Case: HAF 932 adv
https://linustechtips.com/topic/964258-help-with-custom-kernel/#findComment-11701533
i need to just have someone to finish a kernel. i just need to add oc compatibility or whatever
https://linustechtips.com/topic/964258-help-with-custom-kernel/#findComment-11702019
I will code for food :D
Sudo make me a sandwich
https://linustechtips.com/topic/964258-help-with-custom-kernel/#findComment-11702428
5 hours ago, Franck said:
You would very likely be quoted around 15 hours of work on that. and that is around 1,200 $ of work.
Android kernel is an already well developed Linux kernel. Anyone can just like change the CPU governor to like performance, which overclock the base frequency to the maxuim turbo, patch it up as some random kernel and then hand it to the op for a few bucks without much difficulty. Op would have no idea he could just done it as easily himself if he rooted his phone. Raising frequency of battery life is gonna destory the battery btw
https://linustechtips.com/topic/964258-help-with-custom-kernel/#findComment-11706080
