Can someone help me woth this. I have a feeling its the cord of the monitor because when we open the lid more or close it more it gains color and such. The computer is a hp 15-f233wm.
I need to know if i can fix this myself or if it needs to be repaired by proffesionals. If i can fx it myself can i get a step by step. Thank you.
https://linustechtips.com/topic/964254-help/
You need a new screen
Pc Specs
CPU: I7 6700k 4.5Ghz  Motherboard: Asus Z170-A Ram: Corsair Vengeance 16GB DDR4  Cpu Cooler: Corsair H100i v2  Storage: Crucial MX300 525GB/Hitachi Deskstar 3TB  Graphics Card: GTX 1080 Founders Edition Case: Corsair 750D Power Supply: EVGA SuperNOVA 850w Keyboard: Corsair k70 Mouse: rival 300
https://linustechtips.com/topic/964254-help/#findComment-11681809
depend on how you feel about tearing it apart, you could fix it your self after buying a new screen online, but I would just take it to a repair store
https://linustechtips.com/topic/964254-help/#findComment-11681815
--SNIP--
That's not the cord - you have a cracked LCD screen. You could certainly take your laptop apart, get the part number from the back of the LCD, then try your luck buying a replacement screen from eBay or Amazon. If you provide the exact serial number or product number of that HP laptop (found on a sticker / printed on the bottom of the laptop, sometimes under the battery) I'd be happy to lookup the part number for you to make it easier. Nevermind! I found it from the model number you provided: http://partsurfer.hp.com/Search.aspx?type=PROD&SearchText=L0T33UA
However, if it's this laptop that you have https://support.hp.com/ca-en/document/c04936059 then it might not be worth replacing the screen, as the money and/or time may be better spent on a newer laptop, depending on your needs. You're looking for a replacement Display Part # 732080-001 DISPLAY RAW PANEL HD BV.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/964254-help/#findComment-11682186
