So after a year and a half and 2 Razer Mambas, I've finally snapped and am in search for a new mouse. I am in love with the shape of the Mamba, and can't stand the shape of the g900. The sensor on the Mamba was also lacking, as it was still a laser sensor. Another factor that isn't necessarily a deal breaker is a charging dock, as I hate having a cable mess. Anyone know of anything that they would recommend?
https://linustechtips.com/topic/963995-help-with-wireless-gaming-mouse/
PWM 3367 so it should be great :D
It supports Qi wireless charging so u can go full wireless even when charging.
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
Just now, Jacob Canale said:
Does it come with a Qi charger?
Unfortunately no.
But u can get a cheap Qi charger to work with it, or get the MM1000 qi charging mousepad.
U can charge your Qi-compatible phones and mouse there too.
4 minutes ago, mikedrewsmy said:
Unfortunately no.
I have a Samsung wireless fast charger, would that work?
Yes it should be working fine
Logitech is soon to release their Logitech G Pro Wireless, it's not cheap though. But worth considering https://www.anandtech.com/show/13269/logitech-launches-g-pro-wireless-gaming-mouse-with-16000-dpi-sensor
Processor: Ryzen 5950x GPU: RTX 3080  Mobo: X570 Aorus Pro RAM: 32GB DDR4 3200Mhz CPU Cooler: Noctua NH-D15
Looks nice, but my hands can't handle ambidextrous mice. That's why I loved the Mamba body.
G(4/6/7)03 from Logitech might be something worth looking into.  They have a Mamba/Deathadder design, but it's not as pronounced.
G403 Wireless - Cheaper but no lightspeed (can't find a link to one)
G603 - Has lightspeed but with a weird grey design and no RGB
G703 - G403 with lightspeed and powerplay
If you're unsure about the terminology:
Lightspeed - Logitech's system for really fast and precise wireless connections.  Not absolutely necessary but it is a nice benefit to have.
Powerplay - The mouse can be charged with a powerplay mousepad as you play.
