Help finding a wireless headset?
Go to solution Solved by EmoRarity,
Well, wireless is suckish, gaming headsets are really suckish, and combining the two is some of the worst things you can do for audio. So my recommendation is that you take question over to the Peripherals sub forum, where you can get accurate help.
corsair vengeance 2100
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
Lol I didn't even know there was a section for that. I'll post the question in there. Thanks!
Guest
