so let's roll back a year... my friends helped me film our wedding, and they charged us 0$ Lots of small clips, and here and there's... most of the ceremony is unusable audio wise because the wind wax approaching 30 mph... I told them all you have to do was film son stuff for me.. and I will take care of the rest. .
So here we are almost 1 yr later and i will not matter what put a video together in the next 3 weeks... I need your guys help. any way possible. I'm willing to spend the little money that we have to make this work. I can do the editing myself or whatever. most of the outdoor shots ate gonna have to be music ... I need to find a decent editing software that won't break the bank or find someone who can do it for me.
I cannot afford Adobe premiere... so if anyone has some suggestions in the sun $100 range or can help me out I would really appreciate it.
there is about 1- 2 hours of video I need to condense into 20min... can you guys help me out or point me in the right direction.
again not free will pay for software or help , let me know what I can do. Any suggestions are appreciated.
https://linustechtips.com/topic/963648-okay-i-need-some-help/
Davinci resolve is free and epic, can only recommend it
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/963648-okay-i-need-some-help/#findComment-11676013
  • 2 weeks later...
I use Vegas Pro at the moment. Lots of ways to get it 'free' ;)
If you still need this sorting out, I have two more weeks off until I start back Uni, and there might be a possibility I can edit this for you. Send me a DM on here if you are interested or need any help. If not, hope you find good software and do a good edit!
https://linustechtips.com/topic/963648-okay-i-need-some-help/#findComment-11712339
  • 2 weeks later...
Just use DaVinci Resolve. It's free for the base version, you don't need the pro features for what you're going to be doing. If you need help there are hundreds of tutorials on YT for everything from basic editing to color grading and effects.
https://linustechtips.com/topic/963648-okay-i-need-some-help/#findComment-11747744
