I'd personally go for a Corsair RM750X 80+ Gold fully modular.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/963414-plz-help/#findComment-11673819
A 650w would suffice but I would get a 750w instead for more breathing room.
Corsair RM750x should be great. (Some say corsair quality is crap)
So You Wanna Be A Playa, But Your Rig's Ain't Fly,
You Gotta Hit Us Up, To Get A Pimped Out Rig,
You've Got To Pimp My Riggggggg...  (DAMN RIGHT)
https://linustechtips.com/topic/963414-plz-help/#findComment-11673820
1 minute ago, Origami Cactus said:
Because corsiar has made some crap psus
This is mainly the VS series now, the CX series was updated and I think they are using a new supplier (no pun intended). Correct me if I'm wrong.
زندگی از چراغ
https://linustechtips.com/topic/963414-plz-help/#findComment-11673838
Yeah the corsair cx-m Gray label should be much better compared to green label ones.
I only see your reply if you @ me.
https://linustechtips.com/topic/963414-plz-help/#findComment-11673844
550W is plenty.
The G2 550W is available for $50, which is a decent price for it. The Formula 550W $63 if you won't use rebates. For higher end ones, there's the Whisper M and RMx 2018.
If you want a PSU that's as loud as possible, there's the EVGA G3 and Seasonic Prime Gold/Platinum.
19 minutes ago, Origami Cactus said:
Because corsiar has made some crap psus, but the rm750x should be good.
Corsair hasn't made any PSUs.
The old CX was CWT, the new ones are also CWT, and GW for some of the CX450s.
https://linustechtips.com/topic/963414-plz-help/#findComment-11673914
33 minutes ago, Vented_Swing_6295 said:
what is a good power supply capable of overclocking (to the max) pc part picker list:https://pcpartpicker.com/list/28gXV6
p.s. i would appreciate your thoughts on the list
Wait for reviews on the 2080 ti before pre ordering. Also get a G-Sync monitor to make use of the Nvidia gpu.
I would personally go with Thermal Grizzly Kryonaut thermal paste over Arctic Silver.
https://linustechtips.com/topic/963414-plz-help/#findComment-11673925
yeah i wasnt gonna pre order it i would get it after the results
https://linustechtips.com/topic/963414-plz-help/#findComment-11674026
whats a good gsync monitor
https://linustechtips.com/topic/963414-plz-help/#findComment-11674375
A 1080 Ti and 8700K, without OC, will demand maybe 300W. With OC can get up to maybe 450W.
You'd be fine on a 550W unit or 650W unit if you OC super heavily and have a lot of hard drives.
https://linustechtips.com/topic/963414-plz-help/#findComment-11675738
