Just now, seon123 said:
If the PSU only has a 20 pin ATX connector, you probably shouldn't use it.
For the 24 pin ATX, the standard is green for the PS on wire. Short that to ground, any black wire.
Basically the psu isn't fir a computer it's the an old thing from a different computer and I am trying to use it to test a loop. Btw thanks
https://linustechtips.com/topic/963371-20-pin-jumper/#findComment-11673430
