Hi,
 I have a an Nvidia GeForce Titan X and a Tesla c2070,
I use my PC for 3D Designing and Computational Fluid Dynamics.
No Gaming.
I am not sure which GPU should I use in my rig.
config: Core i7-3370
           16GB
           120GB SSD
           2TB HDD
PS: Do I really need a GPU?
https://linustechtips.com/topic/963213-3d-modelling-and-analysis/
Yes you should use a gpu for 3D stuff. But - well - it depends if the program you are using even utilizes a gpu. So you want to check that.
The Titan X is clearly the better choice. Simply because the C2070 is an old card by now. (If I'm not living in some strange world that is).
If you find any grammar or spelling errors please fill out entry permit A38, thanks.
Greetings from germany
Profilepicture by Chibiterasu-chan
  • 2 months later...
