So I gotta say first, I USE THE eGPU, so I don't know if that is the cause of not booting up(but I don't think it is...
I found my PC wouldn't work when I get back to my home and trying to boot it on. My graphic card usually will have it's fan on if I turn my POWER on. (PSU too) even through my PC it shuted.
then I switched on my power, and the graphic card's fan wasn't working.
and then I tried to put my PC on, and it didn't work
I can say my POWER SUPPLY and GRAPHIC CARD is working because I have tested in OTHER pc.
even through I put my PCI-E wireless connector back it still couldn't boot.(The light is not on)
Then I went to the repair store over here in India Mumbai
This PC was bought for around 19,000 NTD(Net Taiwanese Dollar) Converted into USD is around 630$.
And the repair price was for 50,000 RS!!! (Indian Rupees) around 716 USD!
My PC was a local warranty in Taiwan cause I bought it there, then I couldn't repair it here, because I could just get another one instead of fixing it.
So anybody can help me with this issue? I will list My specs below
--------SPECS--------
Model: UN64V (Asus Vivo PC(VivoMini))
CPU: i7-4600U @ ~3Ghz ~ 3.3Ghz
GPU: GTX 950 (ASUS GTX950-OC-2GD5) eGPU 1x PCI-e to 16x PCI connector
RAM: ddr3l 1600 4G * 2
PSU: seventeam 500W
Asus NUC: CPU:i7-4600u | ram: ddr3l 4GB x 2 | ssd: 256GB | Network: RJ45 port, wifi 802.1 ac | usb: USB Gen3 x 4 | SD: SD port x1 | Display: HDMI x1, DP x1| GPU: Intel Graphics 4400 @ 1100Mhz |
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/
5 minutes ago, Gamerfiend_ said:
Its long winded but when I get issues I'm not sure the root cause of I run through the process of elimination, I.e pulling sticks of ram individually & booting inbetween to see if any of them have any issues for example. Check everything so you know you've covered all bases
I have thought the same thing before and I have done the same thing
reinstall the graphic card
memory, ssd (mSATA) and almost everything, but it just don't work.
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668753
11 minutes ago, Gamerfiend_ said:
In that case I would look into grabbing another external GPU connector, if the GPU and power supply works elsewhere & you've tried everything else then I would look into that possibility
I'm not sure the eGPU is even relevant. Might just be a dead motherboard in the mini PC.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668793
14 minutes ago, wojtepanik said:
so they told you that the repair is 700$ but they didn't say what is wrong with it ?
yups, They just say MOTHERBOARD, MOTHERBOARD, MOTHERBOARD...
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668797
My computer should work without a graphic card
It can use a iGPU so that shouldn't be the problem since I tried to put it on with iGPU and I took off the eGPU
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668802
They're probably right. The board contains the soldered processor, and it's Haswell generation hardware (~2013/2014) so it's not easy to find either.
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668804
But in TAIWAN they fixed so fast, just like change another one for free because I was in Taiwan, so..
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668806
Taiwanese warranty is apparently not applicable to India. You'd have to catch a flight to Taiwan, get it fixed and fly back to India again. I mean, cheaper than $700 but not super practical. This is all assuming the warranty hasn't run out.
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11668872
my warraty is 3 years, it will run out in 2020 so I don't have to worry about that for now, cuz I only can go back to taiwan somewhat at christmas, sooo
https://linustechtips.com/topic/962910-help-my-pc-wouldnt-boot/#findComment-11684083
