Hi!
So i am planning to make a youtube video, about a 300$ build, but i don't know how to edit videos... ( well, i know the basic stuff, like inserting, cutting, transitioning and adding text to the clip )
I am using Sony Vegas Pro 13 ( i got it free during a school project ) and what i want to do is to have a video of a game, for example Far Cry 5 and add a sideways graph showing the MinMaxAvg Fps, while i am talking.
I know how to make audio and blur out the gameplay, but what i don't know is how to make that graph.
P.S WTF Nvidia??? 799$ MSRP for a single freaking card?!
https://linustechtips.com/topic/962686-need-advice-on-editing/
I would record the video with OBS and you can add a layer to the video that has whatever input you want such as a program that displays your fps. You would add it to the video in a similar was as you would a facecam. After you have the recording gedit it however you want in SVP
⬇ - PC specs down below - ⬇
The Impossibox
CPU: (x2) Xeon X5690 12c/24t (6c/12t per cpu)
Motherboard: EVGA Super Record 2 (SR-2)
RAM: 48Gb (12x4gb) server DDR3 ECC
GPU: MSI GTX 1060 Gaming X 6GB
Case: Modded Lian-LI PC-08
Storage: Samsung 850 EVO 500Gb and a 2Tb HDD
PSU: 1000W something or other I forget
Display(s): 24" Acer G246HL
Cooling: (x2) Corsair H100i v2
Keyboard: Corsair Gaming K70 LUX RGB MX Browns
Mouse: Logitech G600
Headphones: Sennheiser HD558
Operating System: Windows 10 Pro
Folding info so I don't lose it:
WhisperingKnickers
Join us on the x58 page it is awesome!
x58 Fan Page
https://linustechtips.com/topic/962686-need-advice-on-editing/#findComment-11666466
You don't create the graph in Vegas, you create it with another app (Excel, for example) and just import the picture into Vegas.
https://linustechtips.com/topic/962686-need-advice-on-editing/#findComment-11666477
6 minutes ago, _SAITAMA_ said:
Hi!
First off they've been doing 10k MSRP for a while now
Second: why are you making a build for a video you are planning to make?
Why not just spend the that you're otherwise spending on researching literally just rendering the video on whatever crappy i-GPU you have?
i7 8700k 5.0GHz 4.0Ghz Cache (Stock Cooler)
2x8GB 3400mhz RAM 19-19-19-38
GTX 1060 3GB 2050Mhz Core, 9500Mhz Memory
https://linustechtips.com/topic/962686-need-advice-on-editing/#findComment-11666494
1. I already had the build ( i built it 5 months ago )
2. I have an i5 3570 ( NOT a crappy i-GPU ) and a 1050
3. I already have done the benchmarking
https://linustechtips.com/topic/962686-need-advice-on-editing/#findComment-11666527
Yeah OK so as I said just upgrade that 1050 to a 1080 if that'll improve render times with your application or instead upgrade to an r7 1700 and you'll save way more time than you would rendering or whatever on a laptop for the same money + a laptop is a sinkhole for money and can't be bought cheaply used.
https://linustechtips.com/topic/962686-need-advice-on-editing/#findComment-11668014
If you are just looking static graph, do it in Excel and edit in some image editor, Photoshop, Gimp etc. which is best for you. For running graph... I haven't done those. Best would be recording it live.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/962686-need-advice-on-editing/#findComment-11668167
