My laptop is not letting me boot into the bios and when I turn on my laptop it always shows "Reboot and select proper boot device or insert boot media in selected boot device and press a key" but I can't fix it because it's not letting me go in the bios. I tried spamming f12, f11, del and esc but nothing works. plez help
my laptop model number is: Toshiba satellite L15w-b1208
https://linustechtips.com/topic/962442-need-help/
try f2. Note that on laptops F[sth] function keys only work with Fn key pressed at the same time.
Desktop benching:
https://linustechtips.com/topic/962442-need-help/#findComment-11663522
35 minutes ago, TheOpBro said:
thanks, I got it working xD
What did you do?
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
https://linustechtips.com/topic/962442-need-help/#findComment-11663568
