Hi there,
I am a new member and am in need of some help. Recently I purchased a Intel i340-T4 for my home NAS. However a part of the card catches on the end of the pci slot (the part circled in the picture). This means that the card cannot fit into place. Would it be possible to cut the tab off, or would I be better off if I modified a x1 slot to take the card. Or is there some other solution.
Thanks in advance.
Server 1:  CPU: i3 2100T  SSD: 840EVO MOBO: DQ67OW NIC: i340 -T4
Server 2:  CPU: Pentium D  MOBO: Dell Dimension 5150
Switch 1: Netgear GS108
Switch 2: Cisco 3500
https://linustechtips.com/topic/961885-intel-i340-help/
other than a different heatsink it is the same as any other i340-t4,
Intel says that it is compatible with x16.
https://www.mouser.com/ds/2/612/ethernet-i340-server-adapter-brief-257490.pdf
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11659051
Most PCIe cards have that tab - I attached some examples. If that slot doesn't work with that card, chances are it won't work with nearly any expansion card, which seems kinda counter-intuitive.
Are there any board components right up against the front of the slot? What motherboard is it?
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11659473
Intel states that it is compatible with 4x 8x 16x pci ports. because y motherboard is proprietary then there is not enough space  between the slot and the pci bracket. so the  card hits the end of the slot. Could i cut the tab off?
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11660392
If there are no traces on that tab (there shouldn't be any) Its fine to cut it off. I have "modified" plenty of cards before, just be careful.
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11660431
yea thanks for that
i'll cut it off, there were no traces. so if it works then all is good. :)
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11660460
Its still very odd that it touches the slot as surely they are all standard sizes?  Are you absolutely sure its a standard PCIe slot?
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11663232
intel says that it is compatible with all PCIe slots [1x 4x 8x 16x] although it is made for 4x. the tab just gets in the way of a 16x and 8x slot but its fits fine in the slightly more set back 1x [modified] and x4 slot. As i do not have a 4x slot i need to fit it in my 8x slot.
TBH if it doesnt work then I'll probably think abut upgrading the mobo anyway
https://linustechtips.com/topic/961885-intel-i340-help/#findComment-11663464
