Yes, but you should get a Z370 motherboard instead of a B360 if you want to overclock. If you don't, then just downgrade to a CPU that doesn't have the K at the end of the name.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/961580-help/#findComment-11656436
