Based upon a number of benchmarks, for the 6gb version, it seems low for 1080p/preset max settings. They seem to be hovering in the 80's, with 50 being the lowest.
At 1440p, 40-50 fps seems to be the norm with lows being in the low 30's.
What resolution are you playing at?
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/961254-low-fps/#findComment-11653630
I play at 1080p. Decided to check for driver updates (should have done that before making this post) updated and used gefoce experience to optimize destiny and now getting around 95-110 with motion blur off and shadow quality set to lowest.
Note to self: allways update drivers.
https://linustechtips.com/topic/961254-low-fps/#findComment-11653677
38 minutes ago, iTakeThings said:
So I have a liquid cooled 4790k MSI Z97 gaming 5 mobo 16gb ddr3 ram and a MSI Nvidia GTX 1060 6gb card and for some reason I’m only getting around 40-50fps playing destiny 2 on medium settings. Is this normal?
Seems way off.
I have a i7 4790K and I can tell you it's not your CPU, it's capable of much more than that in this title.
A simple driver reinstall may fix it, usually does cure most problems,.. I'd give that a shot first. (Also remove background apps from running just in case)
Replied,...Beat me to it.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/961254-low-fps/#findComment-11653679
