Case Fans?
Go to solution Solved by TheGlenlivet,
Just now, TheCosmosAKAtheNerd said:
Yeah check the dimensions for a MSi gtx 1050 low profile 2gb
I don't know if it will fit with the GPU in there.  If the system works now, I'd put the GPU in and then do some measurements before you buy anything.
So My PC an HP 8300 has a heat sink and has a channel going to the front of the case I ask if its ok to remoce that channel and replace that heat sink for a noctua one i have a sff pc so what noctua air cooler should i use
and also will it be ok to put a noctua cooler thats gonna be used to play high demanding games like BF1
https://linustechtips.com/topic/960653-case-fans/
https://noctua.at/en/products/cpu-cooler-retail/nh-l12s
Something like this?  You need to measure to make sure it will fit, but for a non-overclockable CPU like your I5, you won't need much.
https://linustechtips.com/topic/960653-case-fans/#findComment-11648694
I edited the post look at the bottom BTW
https://linustechtips.com/topic/960653-case-fans/#findComment-11648700
No it has a 120 MM fan wont fit
https://linustechtips.com/topic/960653-case-fans/#findComment-11648706
is it a 65 MM fan ?
The height of the total cooler is 65mm. The fan is a 92mm square
The NH-L9i is shorter at 38mm tall
https://linustechtips.com/topic/960653-case-fans/#findComment-11648734
