Power Supply Crisis
Solved by TheGlenlivet,
2 minutes ago, TheCosmosAKAtheNerd said:yes it doesnt use external power but at max power usage would the GPU not boost up and get lower FPS i am worried it might need more power
No it should be fine. The GPU uses like 75 watts at full blast. The 320W PSU you have should be plenty. There ARE SFF PSUs out there, but I would try what you have first.
