After a couple posts and lots of discussion, i've come up with this system! I think its pretty good but i just wanted to make sure everything was gonna work. Here it is. Thx in advance for any help!
I will also be putting in this rgb kit and fan/ rgb controller because why not, am i right?5b724570e291c_Screenshot(45).png.80dd4dec37aa208efd5ccfaeae6cafce.png5b7245722166a_Screenshot(46).png.f1acccfb132cfb25bd1164aced6ad31b.png
https://linustechtips.com/topic/959957-first-build-pls-help/
what's your budget? it'll work but you're much better off putting the budget on your other components instead.
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11642389
No need to post a screen capture. Above the list on the left is a Permalink, that could be posted instead. Better yet, slick on the [bb] button in the middle above the list and paste the contents.
There should be no need to buy additional thermal compound, the H100i Pro comes with a pre-applied pad.
You might consider an Obsidian 500D RGB SE case as it comes with a lighting node pro module.
G3 psu apparently have some issues and are not as quiet as some of the competition. Consider an RMx or Focus Plus Gold instead.
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11642412
Permalink: https://pcpartpicker.com/list/NMVC4q
Ive chosen an rmx psu but i would really like to stick with the 460x as it looks much better in my opinion. also the lighting node pro cant connect to the rgb strips...
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11644861
4 hours ago, brob said:
Thanks for the permalink.
I apparently erred on the 500D RGB SE case. It comes with a Commander Pro, not a Lighting Node Pro.
Yeah i noticed. It seems like a better case for the money its just ugly imo. The only problem with the 460x is cable management...
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11645717
If you like the 460X, stick with it.
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11645771
On 8/14/2018 at 9:49 PM, brob said:
Everything looks fine.
Did you consider Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3200  instead of Vengeance RGB. It's a newer design with more sophisticated lighting.
Im considering an m.2 ssd so i will hace less cables and more space. Possibly the one in this build. It says compatibility check but idk what the compatibility message means. Pls take a look.
https://pcpartpicker.com/list/L3sNxG
Thx.
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11656655
Thx.
The notes indicate that there is a limitation on the total number of drives supported by the system. Two M.2 drives are supported. Depending on the number and type of M.2 drives installed, up to 2 of the 6 SATA III connectors may be disabled.
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11656689
So all its telling me is i can only have 2 m.2 ssd cards? Also i just did some research and found out sata lll will be a bit slow for what ill be trying to do, so i decided to go with a pci express 3.0 card. Will this free up sata ports?
https://pcpartpicker.com/list/VKxM4q
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11658076
Samsung MZ-V7E250BW and Western Digital WDS256G1X0C would be better and less expensive choices.
As to freeing up SATA ports, what difference does it make if the transfer speed is to low for requirements?
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11658324
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor  ($248.90 @ OutletPC)
CPU Cooler: Corsair - H100i PRO 75.0 CFM Liquid CPU Cooler  ($119.99 @ Amazon)
Motherboard: MSI - Z370 GAMING PRO CARBON ATX LGA1151 Motherboard  ($164.89 @ OutletPC)
Memory: Corsair - Vengeance RGB Pro 16GB (2 x 8GB) DDR4-3200 Memory  ($209.74 @ Newegg)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive  ($67.72 @ OutletPC)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($59.09 @ OutletPC)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case  ($129.25 @ Amazon)
Power Supply: Corsair - RMx (2018) 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Amazon)
Operating System: Microsoft - Windows 10 Home OEM 64-bit  ($94.89 @ OutletPC)
Case Fan: Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.2 CFM  120mm Fans  ($99.89 @ OutletPC)
Total: $1294.35
Generated by PCPartPicker 2018-08-18 12:35 EDT-0400
Use integrated graphics for 2 days, then Gamescom and poof new GPUs come out (August 20th)
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11658343
Total: $1294.35
What is so special about the mx500? Also I'm willing to bet I can't afford one of the new release cards, but will the new you drop lower the price of the older gpus?
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11659801
The MX500 offers great value at a low price.
If you can't afford the new cards, the new ones will likely have the old ones in clearance sale.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11659819
Total: $1294.35
Just found this https://www.amazon.com/Samsung-970-EVO-250GB-MZ-V7E250BW/dp/B07BN5FJZQ/ref=pd_aw_vtph_147_tr_2?_encoding=UTF8&psc=1&refRID=H77YH17WVEGRDGV8THMK
For only about $40 more I think an nvme drive would be a better drive. I just wanna make sure I get something that will work with my motherboard. If I get this will I still be able to run an elgato hd 60 pro?
https://www.amazon.com/Elgato-Game-Capture-HD60-Pro/dp/B014MQIVPS/ref=mp_s_a_1_3?ie=UTF8&qid=1534645206&sr=8-3&pi=AC_SX236_SY340_FMwebp_QL65&keywords=hd60%2Bpro&dpPl=1&dpID=41T1nc8d10L&ref=plSrch&th=1&psc=1
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11659821
It'll work, but it'll make no difference, except if you have a RED camera and are handling 8K footage.
It'll work either way.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11659834
Nice! Less money=More enjoyment knowing i didnt blow my years salary on 1 pc
https://linustechtips.com/topic/959957-first-build-pls-help/#findComment-11659912
