Hello everyone I'm working on a setup for a family friend he was looking for a solution for his TV and Movie collection which are all digital files I have already done some research on my own but was wondering if some experts had some suggestions
Okay so laying it out he wants a 5 - 10 TB capacity smaller solution so like a NAS but wired it should look kind of pretty (Just not industrial) and fit on a shelf.
He is looking for something that he could move and plug into another computer without too much trouble
The storage device should be HDD and should be able to use WD Black performance drives preferably with two or more slots
it should have very high transfer speeds and USB 3.0 and Thunder Bolt 3.0 or 2 capabilities for plug and play with other computers around the house
The PC should be about the size of an IMAC but windows and should spec out around 8GB RAM and a cpu that wont have trouble playing 4k video and regular everyday computer usage
The PC dosent have to have a lot of internal storage but should have at least 64GB of internal storage (Preferably M.2) With Thunderbolt 3/2 port or ports on the back
Also he needs a pretty beefy USB WiFi adapter (External) which i think I've already found but would be open to suggestions on
Thanks for the help and i hope to see all sorts of feedback
Thanks in advance and Cheers!
https://linustechtips.com/topic/959538-mini-pc-with-storage-solution-setup-help/
What exactly do you want?
Do you want a das, thats what it seems like you want.
Id go usb3 as its much cheaper than thunderbolt and basically the same speed for hdds. Just get a external 8tb hdd and you should be fine. You don' t need a high performance drive for movies. Get anouther drive or a cloud service for backups.
