So I was browsing for a pre built system and found one on Best buy, A10-9700 with RX 560 2Gb, 8Gb Ram. I want a pre built because I don't really have the time to wait for parts to arrive since I have a decent amount of multitasking to do. I currently have a system thats an A10-9600P (laptop) that isn't really doing what I need to do. It's on a really good deal, cause I'm on a tight budget. It was originally $600 USD, now $395.
Will it be able to do things like play games and stream at 1600x900, cause the monitors I have are baller, as well as be able to have CAD and maybe Adobe Photoshop open at the same time? I've looked all over the wild internet and haven't found much.
Any and all help is appreciated!
https://linustechtips.com/topic/959526-need-a-little-help/
You can use the laptop and wait for the parts and then build it. But and rx 5y0 can do decent amount of performance, I haven’t used cad on my main rig or adobe photoshop. I would try and get one with a slightly better cpu in it.
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
https://linustechtips.com/topic/959526-need-a-little-help/#findComment-11638650
I would go for Ryzen APU. Old AMD APUs are trash for me
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/959526-need-a-little-help/#findComment-11639072
