You can get a converter that converts 2x 6-pin PCI power plugs into a single 8 Pin. So you need 2 of these.
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11636828
I have a Corsair black cable that has 2x8 pin on can I plug custom cables over that? And I swear I’ve seen in video people with 2x8 pin together
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11636834
What do you mean plug custom cables over that?
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11636836
Just now, sideqcktv said:
Like I want blue and white canlescables I want my pc to look clean with slick custom cables
Yes but if you want your GPUs to work, then you can't use those cables.
PC Specs:
Laptop:
NAS Specs:
M.2 SSDs: None
Total Storage: 12TB
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11636856
Doubt the next card will be 500 bucks.
Order new cables or another 8 pin. Google cable modz or something. Plenty of options out there.
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11637594
have you seen the rumor of the prices if its 500 it would be a steal rumored to be 50% faster then 1080 wouldnt that mean its better then ti>
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11637796
I don’t bother to look at rumors. I don’t care how much it is or how fast it is. I’ll see when it’s released and go from there.
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11637837
ok cause i have a month to refund my 1080 so i would do it just to get a better card lol
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11637855
If you think you can get ahold of said new card at launch and can wait with no card in that time. Also assuming they wont be 700+ usd.
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11637889
yeah if they are 700 at launch then i wouldnt get it but then maybe 1080 ti prices will drop alot might be worth to buy it wouldnt make sense to be cheaper then a 1080 ti considering it would be better
https://linustechtips.com/topic/959272-1080-cable-2x8pin/#findComment-11637897
