Question about a Sennheiser Cable
I own a Sennheiser Game One headset, the cable is detachable and after getting mauled by my cat in a pretty bad shape.
I looked up a replacement and the price is ludicrous for what it appears to be:
https://www.amazon.com/Genuine-Sennheiser-Replacement-Gaming-Headset/dp/B071WQG39D
It appears to be a 2.5mm Male to 2x 3.5mm Male, Though I'm not 100% sure because part of the 2.5mm end is recessed, I wonder if they are functionally different from normal 2.5mm jacks.
I want to create my own cable for when mine inevitably fails using these:
2.5mm to 3.5mm adapter
3.5mm Y splitter
3.5mm aux cable
Which would total out to less than 4 bucks, as opposed to Sennheiser's $35 + shipping.
Would this work?
https://linustechtips.com/topic/959202-question-about-a-sennheiser-cable/
