Hi.
I have a brand new computer I just built but need a wireless adapter. I found one on Newegg which is $7 off and it looked pretty good to me for $18.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166082
To be honest I don't have any idea what I'm doing when it comes to this. If someone could tell me whether this is a good choice or if there is a better choice under $20 that'd be great.
I would like to be able to put it inside of my computer if possible, I don't like extra USB things.
FX 8350 | MSI 650ti BOOST | Gigabyte 970A-UD3P | Corsair CX 430
Diablotek Evo | WD Caviar Green 1TB
Linus Tech Tips Fan!
https://linustechtips.com/topic/95908-wireless-adapter-recommendations/
I had the AE2500 and it was great
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
Anything from Intel, ASUS, Rosewill, and TP-Link will do you just fine.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
So then I shouldn't be worried about the 300/300 Mbps? I jdon't know if thats fast enough or if it even matters.
It should be plenty unless you're streaming high bitrate content over your local network.
