Is my be quiet! Pure Rock Slim in the right side ?
qtnovr
Hi! So I built my new PC (not my first one) but I decided to buy the Be Quiet! Pure Rock Slim because I wanted to overclock the Ryzen 5 2600.
But, I can't go higher than 3.7GHz... Is it because of the side I choose for the fan?
have a nice day!
the side or the direciton of the fan does not make much difference, the temperatures will. How high are the temperatures under load?
normally you would mount the cooler rotated 90° counterclockwise, but shouldn't matter much.
Did you only rise the clocks or the voltage too?
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
I presume you mean the cooler orientation. I doubt that. That orientation should be fine as it's natural for the hot air to rise. It might be the chip's fault. It's not like ryzen overclocks very well. and that cooler isn't really ment for hardcore overclocking anyway.
I'm around 60°C to 65°C, which is absolutely fine. But I though that the fan can be in conflict with the case fan on top (I hope you can understand, I still have progress to do in English ;) )
I just want to go to 4.0GHz, maybe it's too much I don't really know..
I doubt you will be able to reach that to be honest.
what's limiting your overclock? Did you touch the voltages yet?
Desktop benching:
To be honest, I'm a noob at overclocking. I just went to the bios and change the frequency. My Mobo is the Gigabyte AORUS ultra gaming, and I didn't touched the voltages.
Cooler orientation isn't issue, voltages are. You can only go as far with stock voltages, or voltages left to auto. 85C is the limit under stress test that you shouldn't cross.
In the end, it's coolers size that becomes limit, if the chip and mobo aren't. Aka it doesn't BSOD before it overheats.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Then you need to start tuning that. 1.425V is the max for this CPU, but since what you entered in the BIOS doesnt equal to what you'll get, make sure you have HWinfo (in sensor mode) running in Windows while you start stress testing the CPU so you can keep CPU voltage (Vcore) in check
Desktop benching:
in addition to that, don't bump it straight up to 1.425V, but make small increments
use as little additional voltage as possible but as much as needed
- Ryzen Build -
2x Dell UP2516D
23 hours ago, Jurrunio said:
Then you need to start tuning that. 1.425V is the max for this CPU...
I will be surprised if this cooler can take it over 1.3V. Even when Sandy chips are cooler than later gens.
