Hi guys. I'm going to be building a computer in a couple days and I am still undecided on this hat power supply I want. Ove looked at 2 or 3 on amazon, different brands, and read the reviews. There were a couple that said something like it started on fire, or made a popping sound sound and destroyed all there storages. Due to this u am very hesitant on what to get. Any help is appreciated. TIA.
https://linustechtips.com/topic/958393-power-supply/
Just now, InfiniteJordan said:
Anything 400+  I really only need like 300 but I want it to have the flexibility for adding things in the future. I looked at the evga g3 750w 80+ gold fully modular. But that was one of the ones I mentioned about starting a fire.
If you're looking around the 400W range, the Corsair CX450M is a good option, I personally use one in my PC, it's quiet and is built like a tank. It's also semi-modular. Corsair CXM, RM(x), and TX(M) PSUs are all great choices.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/958393-power-supply/#findComment-11629662
What's your Budget/Country and what's the current PC build?
https://linustechtips.com/topic/958393-power-supply/#findComment-11629672
What's your budget on the psu like? Personally though, I would go with one of these.
Corsair TXM 750 watts gold rating - https://pcpartpicker.com/mr/neweggmkt/JfBrxr
SeaSonic focus gold 750 watts - https://www.amazon.com/dp/B0778XF1HL/?tag=pcpapi-20
EVGA Supernova G2 fully modular gold rating - https://www.amazon.com/dp/B00IKDETOW/?tag=pcpapi-20
They all have 80 + gold power efficiency rating. I would go with a 650 or 700 watts platinum rating.
https://linustechtips.com/topic/958393-power-supply/#findComment-11629682
750W is overkill.. The only components that take a good percentage of wattage is the cpu and gpu. What's your cpu and gpu? Will you be overclocking? SLI/X-Fire, another dual gpu setup would require a 650-750W not single gpu setup.
Save the extra cash and buy someone a gift.
I'd recommend the EVGA G2 550W or Seasonic Focus Plus 550W, both gold rated.
Best & worst cases for your money in 2018 are:
Best Cases overall
I) Fractal Design Meshify C - Airflow and relatively quiet, best all around case
I) Phanteks Enthoo Pro M / Special Edition (white interior) - Airflow & full water cooling support
I) Fractal Define R6 - Silent with decent airflow
I) Be Quiet! DB 900 (Full Tower) - Airflow and silent
I) Fractal Design Meshify C mini (mATX)
I) Corsair 400C - Only use with low end components, no 1080 / TI
I) Phanteks 350X - Only use with low end components, no 1080 / TI
I) Fractal Design Focus G
Cases that may be worth your money
I) Thermaltake G21 - GPU and CPU cooling issues, modest tweaking
I) Silverstone RL06 / Pro - Mustard/Ketchup wires, Shitty cable management, Poor front radiator support, useless psu filter, stupid ssd layout
I) In Win 303
I) Coolermaster H500 no suffix - if 200mm fans are your thing
I) NZXT H700 non "i" version - Needs to come down in price to be worth it
I) Corsair Carbide 100R - Suitable for low end builds
The worst cases - Do Not Buy
I) NZXT S340/Elite, H500, H440 (everything except the H700) Reason: Poor airflow
I) Coolermaster Masterbox 5
Majority of cases on the market
https://linustechtips.com/topic/958393-power-supply/#findComment-11629711
What are your system specs? That's the most basic information that we need.
https://linustechtips.com/topic/958393-power-supply/#findComment-11629834
550W should do you fine with plenty of room for expandability.
Best Cases overall
I) In Win 303
https://linustechtips.com/topic/958393-power-supply/#findComment-11630702
