Ram Help PLS (DDR3 vs DDR4) (For my pc build)
30 minutes ago, soggytofu said:Yeah, so will ddr3 fry the cpu? And if so, is there a way to decrease the ram watt usage to a certain level for it to be compatible?
DDR3L exist so just get that if you're afraid of burning it and want to be sure it will be compatible.
Now everything in the spoiler below is really what you "could do" and not what you "should do", use only as information and not as advice
DDR3 may run just fine, contrary to what the other poster said, it's really down to the support on the motherboard itself, even if the CPU "officially" only support DDR3L.
Just that the memory controller on that CPU is limited to 1.35V, hence if you put in "normal" DDR3 instead of DDR3L(Really the same thing, the L stand for Low Voltage), you'll have to downclock the RAM a little so that it goes from 1.5V to 1.35V. (The bios will likely do this by itself, if not it's easy to do it)
Give this a read if you want to learn more.
This is somewhat like how CPUs used to only officially support RAM up to 1.5V, but manufacturers made RAM sticks that were 1.65V and you could overclock it to reach said voltage, did it burn CPUs? Nope...
I also can't find a single mention of a CPU's memory controller having been burned out due to using higher voltage DDR3 over DDR3L, online.
This might be a bigger issue on a laptop, where the CPU isn't adequately cooled, but on a desktop, the memory controller on the CPU should be able to handle the higher voltage just fine with the better cooling it gets.
That said, it's all down to the motherboard support. If the manufacturer decided to prevent RAM above 1.35V from working, the system will simply reject the RAM and not even POST. Hence, unless you have a bunch of DDR3 on hands already to try it out, do not go out and buy some.
Just get DDR3L if you do not have any DDR3 at the moment.
(And in the unlikely scenario that the CPU "does" burn out, it wouldn't happen straight away, it would be months, maybe years from now, so you're free to try it out if you have some spare DDR3 on you)
But hey, better safe than sorry, if you have the option, get DDR3L.
