see photo for details
I installed the overclocking software from my Motherboard and let it do its thing (Asus Crosshair VI hero)
I really enjoy my Ryzen 7 1800x running at 4100Mhz and my H110 (240mm Rad) is keeping things cool at about 62c
I Noticed that my Vcore is at 1.591v but I see that the VID is only 1.350v
should I be worried about the high Vcore?
https://linustechtips.com/topic/958006-overclocking-question-vcore-or-vid/
Yeah, usually Vcore isn't supposed to go over 1.5v.
What voltage did you set your overclock with?
Yes you should be.
1.591v is far beyond the safe limits for any Ryzen CPU unless you are using liquid nitrogen.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
Vcore is the one you should care about, and that Vcore is crazy high for ambient cooling. How did you tune your voltage?
Desktop benching:
Just now, officedemon said:
@Crunchy Dragon I used Asus program called "Dual Intelligent Processor 5" and clicked the 5-way optimization, I did not overclock with the BIOS
dont use oc software or presets, those do dumb shit like overshooting Vcore.
Desktop benching:
Overclocking via BIOS is the best way to do it. And as @Jurrunio said, a lot of auto overclocking programs like that will overshoot your Vcore.
Yuck.
If you absolutely don't want to OC in your BIOS, then at least use Ryzen Master.
On 8/9/2018 at 1:03 AM, Shimejii said:
Vcore is Way to high there o.O Unless theres something being reported wrong
if it was correct I'd think that my temps would be a lot higher?!?
CPU-z and hardware monitor both say my max CPU Vcore is 1.591
but upon opening Ryzen Master it seems that my max CPU Voltage is 1.35v?
Edit: here is a list of my parts if it helps https://pcpartpicker.com/list/
Edited by officedemon
