Heyy, got a few questions I need some assistance with. number one I'm getting a new mother board in two hours its being delivered... just wondering im swapping it for an old one, I know it sounds stupid but do I uninstall old mobo drivers swap it for the new mobo and install drivers boom bada bing!. and the new question number two is yesterday I was experiencing some crashing like my computers sound crashing a loud buzz from the headset and then my pc restarts it self I did just put some new hardware in e.g. R9 290 and a Corsair RM 750w and also when I played cod 4 my display driver stopped responding and then the computer restarted again I have windows 8.1 and it wasn't activated, I activated it and it updated plus I reinstalled direct x on cod 4 and then "touch wood" its not happened since any ideas what it could have been just incase it happens in the future. just incase my system specs are..... AMD Phenom x6 1090t , 8gb patriot viper ram, Asus M4A88T-M, ASUS R9 290, CORSAIR RM 750W, SEGATE 1TB. Thanks :)
https://linustechtips.com/topic/95787-need-help-software-problems-i-think/
I havn't overclocked a thing and my temps are cpu highest its gone is 35 c gpu is have is set so it doesn't reach 80 c and my mobo on hw monitor cause ive always wondered what this ment cause it looks bad... TMPIN0 MAX 29 TMPIN1 MAX 25 TMPIN2 MAX 128. CLOCKS: core clock 947 memory clock 1250 on idle it goes down too gpu clock : 300 MHz memory: 150mhz and my cpu is clocked at 800mhz - 3200 MHz
Backup your OS in case of a driver failure, but the new motherboard install should be fine. Those sound like some driver problems, probably fixed through some updates. It was probably caused by the new graphics card, just needs newer drivers. Your temps look fine. I think the TMPIN2 is just a monitor for another graphics card. Since there isn't a third place to monitor, it probably just gives a max reading.
Using Tapatalk
