Hey guys,
first of all my specs :
Gigabyte Z97X-Gaming GT
Intel core i7 4790K (cooled by noctua NHD-15 and sufficient air flow in the case)
2x G.skill ares 1600mhz, 1.5v cl8 4gb
2x G.skill ares 1600mhz, 1.5v cl9 4gb
Nvidia Geforce GTX 970
Now to my problem:
I recently did an upgrade on my CPU from an i5 4460 to said 4790k. I installed the CPU, checked temps and on stock it was running at well over 100C under load so i made sure the cooler was mounted correctly and then did some digging and long story shot: i set Vcore from well over 1.2 to 1.108 and the temps were under control. Now to the current problems. Running it at the stock turbo frequency of 4.4ghz would cause Bluescreens when stresstesting and the system wouldn´t boot properly sometimes so i turned off the turbo and at least in the timeframe that it would BSOD whith turbo on everything ran fine (didn´t have the time to do very long stresstests but no problems were showing up at over half an hour p95 while with turbo on it would crash after hardly 10 seconds).
Now with the stock frequency just the boot problem appears which shows itself in this way: while starting up the BIOS launches and displays that the current settings seem to cause problem and suggests i change them. I tried playing around with the Vcore voltage a little with stock and turbo clock but that didn´t help. Also i never had any problems under normal use with either of the settings except the booting thing.
So to clarify: things i changed in bios: Vcore voltage
                                                            Turbo boost off/on
                                                        ram timings from 11,11,11,28 to 9,9,9,24
idealy i would likke to run the CPU at the turbo speed but if i could at least achieve a stable system that would be great. ill add a screenshot of the debugging tool for the BSOD.
if you need any more info just let me know.
any help would be greatly appreciated.
Kind Regards
https://linustechtips.com/topic/957740-problems-with-i7-4790k/
2 minutes ago, MaxEEE said:
Hey guys,
Now to my problem:
                                                            Turbo boost off/on
Kind Regards
If it's crashing you'll need more voltage...
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624110
First of all, congrats on breaking the forums.
As for your stability problem, I suspect not enough voltage to stay stable. Have you apply fresh thermal paste after swapping CPU?
Desktop benching:
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624121
I hope you did apply the thermal paste properly. Otherwise the thermal paste between the IHS and the chip has deteriorated and needs to be changed ... that happened to me once.
What they said is correct, get your temps under control
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624123
11 minutes ago, MaxEEE said:
Hey guys,
Now to my problem:
                                                            Turbo boost off/on
Kind Regards
you buy the i7  new or used?
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624156
thanks for the quick replys guys.
as for my temps thermal paste etc.. temps are fine now package hits maybe 72c when under load and i made sure thermal paste is applied correctly.
as for the voltage i tried raising it to no result except highering the temps (not to concerning levels tho). maybe i didn´t raise it enough? i put it up to 1.30 with turbo enabled, same problem. to low voltage would also explain the boot problems? intels recommended voltage is 1.108.
also the cpu is new.
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624164
if you arent oc the cpu leave the voltage in auto  but just be sure  that isnt so high or it will give you high temp
sometimes the motherboard deliver more than recomended
ihave a i7 4790k i dont oc i leave in auto  in hwinfo it say it gets 1.2 v max at stock with turbo on
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624188
the i7 you have should have stock voltages of up to 1.273 volts under load. No wonder your PC keeps crashing ._.
There is something wrong with your chip. And the only thing that I can come up with is low thermal energy flow between the IHS and your cooler.
Either get a new CPU or try to fix that ._, I don't know how much you would have to underclock your CPU to mach those voltages or if that even works at all ...
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624225
i mounted the cooler like 3 times and also tried it with a different one. after the problem showed up i did some research and found people having the same problem with the proposed solution being to lower the voltage which for some worked out at voltages well below 1.2. so i should try raising it as much as i can without making it evaporate and if that doesnt work something is wrong with the cpu?
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624258
Ok so far so good. i upped the voltage to 1.90 which resulted in temps of blistering 94C during prime 95 but no BSOD so the voltage seems to be the cause of it.
On the weekend i will try to get those temps in check (making extra sure cooler is mounted correctly and adjusting the voltage some more) but since i will not even get close to those temps in normal use i will leave it at that for now. i will post some results after i have done some further testing.
thanks a lot so far.
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624380
Run mine at 1.26v @ 4.6. Used to do 4.8 but doesn’t do much aside from extra heat.
If it runs at default settings than it isn’t an issue. Need bettter cooler or to delid it.
Either way it needs its voltage, no getting around that except doing real world testing over a longer period.
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624398
Idk, I haven’t stress tested it in while. I only care about real world. Actually got it up to 1.28, forgot about the adaptive +
Fans are only prolly at 40/45%
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624424
oh wow under realworld load i hit close to 70 with 1.90. i guess im grossly incompetent then O.o. gonna recheck my cooler then.
my ambient is at like 30c atm but that shouldn make a 20C difference if you actually reallyhave lower ambient temperetaures that is.
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624437
Those are high temps for me. Prefer little to no noise while gaming as I record a lot.
Room prolly sits closer to 80 or high 70’s but that doesn’t last long with two pcs and 5 monitors heating up the room fairly quick.
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11624555
ok Guys thanks for your help, im now running stable with 1.26v vcore and 4.6ghz.
i hit max 70C during cinebench and while i still hit around  100c in p95 it doesn´t concern me much because the workload seems to be quite unrealistic.
so thanks again and keep on doing what you are doing :)
https://linustechtips.com/topic/957740-problems-with-i7-4790k/#findComment-11633782
