Just now, JamesElopre said:
Should i get just 1080 or 1080 ti? games i'm gonna play. Gta 5, Csgo, pubg, fortnite, some other offline games like farcry , crysis , and more
I know for a fact that PUBG eats ram pretty hard so if you don't have 16gb of ram already I would buy the 1080 and buy more ram with the spare money, If you do have a decent amount of ram then fuck yea get the 1080ti that things a monster
https://linustechtips.com/topic/957491-help-me/#findComment-11621726
30 minutes ago, JamesElopre said:
Should i get just 1080 or 1080 ti? games i'm gonna play. Gta 5, Csgo, pubg, fortnite, some other offline games like farcry , crysis , and more https://ca.pcpartpicker.com/list/j7ncRJ
This would be dependent on what settings you are planning to use and what frame rate you would consider are good or acceptable. The GTX 1080TI by Nvidia is faster than the GTX 1080 made by Nvidia although the difference in performance may or may not be able to be justified for the cost (depending on the computing usage). Calculate the performance per dollar of each card and the one with more performance for the dollar would be the best price to performance card. Unless you want every aspect of your system to be at the very highest in a performance that you can get, price to performance is going to be a good way to determine which card would be an overall "better purchase".
Hope this information post was helpful  ?,
        @Boomwebsearch
https://linustechtips.com/topic/957491-help-me/#findComment-11621849
if u want to run every game in ultra (except for pubg that runs in low) you should go for the 1080Ti
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/957491-help-me/#findComment-11621908
Ti without a doubt. 1080 is too weak.
https://linustechtips.com/topic/957491-help-me/#findComment-11621928
