So I think people need to know how to figure out what power supply wattage is required of your PC. Here is a handy tool I have found during my research.
ASUS Calculator link--->http://support.asus.com/powersupply.aspx
if you need to know how to use it, enter the exact specifications of your computer and it will tell you the recommended amount of power supply wattage needs to go into your computer to run healthy.
NOTE does not include overclocking for power supply usage if you are overclocking you will most likely have to have a higher wattage than it recommends to ensure it does not under power your pc and fry it as a result.
https://linustechtips.com/topic/95737-pc-power-supply-advice/
There's also pcpartpicker which does it as well
Heaven's Society - Like Anime? Check us Out Here!
https://linustechtips.com/topic/95737-pc-power-supply-advice/#findComment-1281479
nice if the mods/admins don't mind links then post it and ill check it out and add it if you want
Links are fine as long as they aren't against the rules like for advertising and such.
https://linustechtips.com/topic/95737-pc-power-supply-advice/#findComment-1281490
http://pcpartpicker.com/ almost everyone here uses it to help make builds for people.
https://linustechtips.com/topic/95737-pc-power-supply-advice/#findComment-1281496
