NEED MAJOR HELP PLEASE
Go to solution Solved by Glenwing,
ok, do I put them on a usb and just access them when im done booting?
Yes, download them on another computer and put them on a flash drive, they are usually executables.  Then run them on the other computer after you boot into windows like installing any other program.
So my mom bought windows 7 professional OEM and installed it for her, I chose the custom installation that removes everything off the hard drive, it boots into windows 7 professional and everything is gone and I thought all I needed to do now was just connect to the internet and I was wrong. Next thing you know no wifi driver and the whole network thing needed to be troubleshooted, then I wanted to fix the screen resolution because it was 800x400 and realized the Nvidia drivers were gone too. Im freaking out right now because thats my moms main source for her work. Any help please, just please!
https://linustechtips.com/topic/95709-need-major-help-please/
Download the drivers from another computer, transfer it to a thumb drive, then use it to install on the computer.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/95709-need-major-help-please/#findComment-1281172
https://linustechtips.com/topic/95709-need-major-help-please/#findComment-1281175
install motherboard drivers
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/95709-need-major-help-please/#findComment-1281176
That's what you do to get the drivers on there, if it doesn't work then there isn't much else to do, you won't have drivers.
Come back and tell us whats up
KK thanks guys! If I dont reply soon either I accidently fell asleep or she told me to get rest and fix it tomorrow.
https://linustechtips.com/topic/95709-need-major-help-please/#findComment-1281195
