What on the board has failed?
Generally speaking, though, it's more cost effective to just replace the board as they generally aren't user-serviceable with any reasonable manner of ease.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11612986
What problems were you having? What beep-codes? Why do you think it was your motherboard rather than another component?
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11612989
Looks like more than just motherboard.
You see the small rectangle by the button cell battery?
See how one of the memory sticks is missing an IC?
WTF is OP doing??
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11613003
See how one of the memory sticks are missing an IC?
WTF is OP doing??
I didn't much pay attention to the photo if i'm honest. I didn't know what I was looking for when discussing what had failed, so it did no good. You're entirely correct though. There's a number of things wrong here.
The chipset appears to be missing it's heatspreader, and it looks like one of the dimm sticks has a fairly jacked up spreader as well
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11613024
Yeah, OP removed the heat-spreaders on the mobo (they're in the top right of the picture).
@-rascal-I can't quite tell what IC you're talking about on the GPU, but the rectangle is a module from a stick of RAM (Bottom stick, fourth from left).
You've got quite a few problems here. I'm not sure any amount of advice would help (beyond recommending not to disassemble components).
Regardless, if you've got any questions, feel free to ask.
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11613051
@Imbellis, yeah corrected that.
At first, I saw the empty SMD points for VRAM IC's on the back of the GPU, but realized it could be a 2GB GPU with a 4GB PCB, etc.
Double checked and noticed one of the RAM modules is missing a memory IC, and the size fits more of a DRAM IC than VRAM IC.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11613072
  • 2 weeks later...
On 8/5/2018 at 6:33 PM, Daniel c Stone said:
My mother board kicked the pooch, ordered a new one Asus rog instea, bit if I can I would like to try to fix it, already contacted MSI and cyber power
As for what has failed, the led code says Ram and CPU are Dead flutters between 3 error code 59 64 55
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11658006
Have already son that replaced the board with ASUS Rog with 8th gen 8086K i7 and G
skill Ram, and optaine ssd
https://linustechtips.com/topic/956480-linus-i-need-help/#findComment-11658014
