Just now, Chr3480 said:
I have the 1070ti EVGA, but whenever i play fortnite, it only does like 30% usage. Wtd
Rest of your Specs?
CPU?
Memory Speed?
PSU?
What else is running at the same time?
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/956188-low-gpu-usage/#findComment-11610693
10 minutes ago, Chr3480 said:
Nah actually like 60% when ingame
I'd guess you're playing Fortnite with VSync enabled and CS Go with Vsync disabled. And you graphics card can do 60 FPS in Fortnite single-handedly that's why you don't see that much utilization.
https://linustechtips.com/topic/956188-low-gpu-usage/#findComment-11610778
How's the FPS. If it's high enough you should not worry. Also if you want to check if everything is okay download some benchmarking tools like Heaven or 3Dmark. Also check Nvidia Control Panel settings.
https://linustechtips.com/topic/956188-low-gpu-usage/#findComment-11610781
Its just that when im playing my favourite gaming, fortnite, then i would like for my gpu usage to be higher than 40-50%
https://linustechtips.com/topic/956188-low-gpu-usage/#findComment-11610794
I havent got v-sync on fortnite
https://linustechtips.com/topic/956188-low-gpu-usage/#findComment-11610800
On what settings you are playing? If you are playing on low res and with vsync you can't expect high gpu usage.聽
https://linustechtips.com/topic/956188-low-gpu-usage/#findComment-11610804
