I've been using NDI for a few days now and for some reason it seems to cause artifacting. I haven't really found a solution, though I did find out if I do some ass backwards resizing, I can minimize the amount of artifacts that are present.
This screenshot is taken straight from the streaming PC's preview (not an encoded video) https://i.imgur.com/787KOtF.jpg
If I use NGINX and broadcast to VLC, these are the results using the exact same settings otherwise https://i.imgur.com/VGMzDw7.png
As you can see, switching from NDI to NGINX fixes the issue. However, NGINX seems to have a disconnecting issue on my, which makes it unreliable and not an option.
Thoughts?
Gaming Rig
CPU: Intel i7-6850k @ 4.2GHz
GPU: 2x FE GTX 1080Ti
Memory: 16GB PNY Anarchy DDR4 3200MHz
Motherboard: ASRock X99 Extreme 4
Encoding Rig
CPU: Ryzen 7 1700 @ 3.7GHz
GPU: GTX 1050
Memory: 8GB Curcial Ballistix DDR4 2133MHz
Motherboard: Gigabyte AB350M-DS3H
https://linustechtips.com/topic/956071-ndi-with-obs-causes-compression-artifacts/
