system configuration
Go to solution Solved by -rascal-,
17 minutes ago, For The Damaged Code said:
so when i go to system configurationand the boot and then advanced option there is somthing called number of processors i find that theyre 1 if i change it to 2 {my maximum) will it effect performance and and does it even change the processors number ?
The setting allows you to restrict/limit the number of cores used.
You want to use as much cores as available...why would you WANT to limit it?
Leave the 'Number of Processors' box un-ticked.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/956011-system-configuration/#findComment-11609111
